After encoding verify written audio
  • Thg6276
    • Aug 2008
    • 187
    Hi, I rip all my cds in flac (compression level 8) in secure mode & accurate rip and clear read cache with fua & c2 errors pointers.
    For the moment the case : "After encoding verify written audio" is unchecked
    I would to know if it is necessary to verify written audio after encoding or not
    Thanks for help
  • Jeff Flowerday
    • Mar 2008
    • 105
    Re: After encoding verify written audio
    It verifies that the encoding to flac files was done properly. Turn it on, it slows things down a bit but it's just another accuracy check that will give you peace of mind.
    • dypsis
      • Nov 2008
      • 61
      I don't notice any difference when checking the Verify box when ripping to FLAC.
      It doesn't appear to do anything.
      And I don't even see a Verify check box for LAME (MP3).
        • 46198
        Lossy codecs cannot be verified as the data stored is not exact 1:1 of the source.
        • texasflood
          • Jul 2008
          • 58
          When exactly does it decompress the flac file and verify the written audio. I' ve used it with and without and haven't noticed a difference time wise. I assume it would then have to compress the file back to flac, which would involve additional time. I'm just not seeing how it could be doing this and not taking any longer to rip than w/o the box checked.
            • 46198
            At the end of writing, it would only take about 2 seconds.
            • QED
              • Dec 2009
              Two seconds to decompress and compare is incredibly fast; is this per track or for a typical CD? Can you please explain the the mechanism used to verify the written audio - MD5 Checksum? Also, how does one know whether the written audio has actually been verified? As far as I can see there is no confirmation and nothing is written to the log file, is there an option to turn confirmation on.
                • 46198
                Per track. MD5 checksum. There is only a log if verification fails.
                • FLAC 1
                  • 22
                  So spoon if i converted WAV files to flac without the verify button, i can still verify it with the original wav files and flac files with the CRC Calculation right ?
                  So its basicly the same as the verify option correct?
                  Just calculate CRC from Flac and original WAV and if everything is the same its also been verified or does that verify does something else to ?
                    • 46198
                    Yes. Also the flac files have an inbuilt CRC so once you are sure they are correct, convert the FLAC files to Test conversion, any errors would show at the end.
                    • FLAC 1
                      • 22
                      Thanks for all this info your da man spoon, dbpoweramp is the best program ever.
                      • Thg6276
                        • Aug 2008
                        • 187
                        Bonjour,
                        Now if we use Perfect Tunes to verify the ripped files, is it always necessary to check the case "After Encoding Verify Written Audio" or not ?
                          • 46198
                          It is not required.
