"Pad track number to 2 digits" does not work with DMC R13 and FLAC R12
  • tschan
    • May 2007
    • 12
    I checked "Pad track number to 2 digits (ie 02)" and un-checked "Track number without track count (ie 2 not 2/9)" in the CD ripper but foobar2000 shows the track number without the leading zero. Is this a bug or am I doing something wrong?
    I'm using DMC R13 and FLAC R12.
    Greets
    Re: "Pad track number to 2 digits" does not work with DMC R13 and FLAC R12
    What idtag is being used (audio format)?
    • tschan
      • May 2007
      • 12
      Vorbis Comments with FLAC (if that's what you want to know, otherwise please rephrase your question )
        Hold the mouse over the flac file, does it show the padding in the popup?
        • tschan
          • May 2007
          • 12
          A picture says more than a thousand words:
            Will look at it for r13.1
              The issue is in the FLAC codec, not R13.1 (cd ripper) so will be updated next FLAC update.
              • tschan
                • May 2007
                • 12
                Thank you for your fast replay.
                • tschan
                  • May 2007
                  • 12
                  So what's the current status? When will a fixed version of the FLAC codec be released?
                    We are in the process of preparing R13.2, it will have FLAC as standard so we will fix asap.
