Newbie needs help with options
  • hanlk
    • Aug 2008
    Dear all,
    I just purchased the this program (dbpoweramp Reference 13) and I am unable to access the 'Secure Ripping' and 'PerfectMeta' options. Can someone please help and tell me where I can find these features?
    Many thanks!
    Re: Newbie needs help with options
    Check in dBpoweramp Configuration (shown after installing registered version) that Reference is infact registered.
      The options are located in the CD Ripper. You have to click on the "Options" button, not the arrow beside it. But, as Spoon said, check dBpoweramp Configuration to make sure you show as Registered and PerfectMeta shows 1 year of access.
      • hanlk
        • Aug 2008
        Ok thanks guys. I had clicked the arrow, and not the button.
