What do I do after I "reset to zero" my Sample Offset in the ripper options
  • poetryrocksalot
    • Jul 2008
    • 12
    My Sample offset was +102, but now it says "AccurateRip to Find". What do I do?
    My drive read cache is only 4 KB? Is that a little too small? The detection only give me 4 KB. It was about 1024 KB before the test I think.....
  • poetryrocksalot
    • Jul 2008
    • 12
    Re: What do I do after I "reset to zero" my Sample Offset in the ripper options
    I can not edit my post for some reason...anyways I fixed the offset problem, but
    can I know what it is anyways?
    Also, I am going crazy over the fact that when i check online people have over +600 KB for read cache size, when I only have 4 KB. What do I do with only 4 KB? And what happens if I set it back to the original 1024 KB?
    FUA is not supported on my driver btw...
    Also, here are some more information and log proof of my cache size in effect: (Are there anything wrong?)
    dBpoweramp Release 12.4 Digital Audio Extraction Log from Wednesday, July 16, 2008 5:34 PM
    Drive & Settings
    Ripping with drive 'D: [MATSHITA - DVD-RAM UJ-850S ]', Drive offset: 102, Overread Lead-in/out: No
    AccurateRip: Active, Using C2: Yes, Cache: 4 KB, FUA Cache Invalidate: No
    Ultra:: Vary Drive Speed: No, Min Passes: 3, Max Passes: 6, Finish After Clean Passes: 2
    Encoder: Wave -compression="PCM"
    Extraction Log
    User Stopped Ripping
    dBpoweramp Release 12.4 Digital Audio Extraction Log from Wednesday, July 16, 2008 5:35 PM
    Drive & Settings
    Ultra:: Vary Drive Speed: Yes, Min Passes: 3, Max Passes: 6, Finish After Clean Passes: 2
    Extraction Log
    dBpoweramp Release 12.4 Digital Audio Extraction Log from Wednesday, July 16, 2008 5:36 PM
    Drive & Settings
    Extraction Log
    Track 1: Ripped LBA 0 to 22133 (4:55) in 0:34. Filename: C:\Users\User\Desktop\Encoding Folder\01 - Ludacris - U Got A Problem¿.wav
    AccurateRip: Accurate (confidence 19) [Pass 1]
    CRC32: 50F466C8
    Track 2: Ripped LBA 22133 to 40828 (4:09) in 0:23. Filename: C:\Users\User\Desktop\Encoding Folder\02 - Ludacris - Game Got Switched.wav
    AccurateRip: Accurate (confidence 20) [Pass 1]
    CRC32: 79712D94
    Track 3: Ripped LBA 40828 to 57568 (3:43) in 0:19. Filename: C:\Users\User\Desktop\Encoding Folder\03 - Ludacris - 1st & 10 (Feat. Infamous 2-0 & Fate Wilson).wav
    CRC32: 44AE0E3D
    Track 4: Ripped LBA 57568 to 78261 (4:35) in 0:22. Filename: C:\Users\User\Desktop\Encoding Folder\04 - Ludacris - What's Your Fantasy (Feat. Shawna).wav
    CRC32: B851DF08
    Track 5: Ripped LBA 78261 to 83000 (1:03) in 0:04. Filename: C:\Users\User\Desktop\Encoding Folder\05 - Ludacris - Come On Over (Skit).wav
    CRC32: 35C3F31B
    Track 6: Ripped LBA 83000 to 102641 (4:21) in 0:19. Filename: C:\Users\User\Desktop\Encoding Folder\06 - Ludacris - Hood Stuck.wav
    CRC32: 9C05B509
    Track 7: Ripped LBA 102641 to 115066 (2:45) in 0:11. Filename: C:\Users\User\Desktop\Encoding Folder\07 - Ludacris - Get Off Me (Feat. Pastor Troy).wav
    CRC32: 3F91D876
    Track 8: Ripped LBA 115066 to 128669 (3:01) in 0:12. Filename: C:\Users\User\Desktop\Encoding Folder\08 - Ludacris - Mouthing Off (Feat. 4-Ize).wav
    CRC32: FF7FCC0A
    Track 9: Ripped LBA 128669 to 151557 (5:05) in 0:19. Filename: C:\Users\User\Desktop\Encoding Folder\09 - Ludacris - Stick 'em Up (Feat. UGK).wav
    CRC32: 1B8AFB2E
    Track 10: Ripped LBA 151557 to 154769 (0:42) in 0:02. Filename: C:\Users\User\Desktop\Encoding Folder\10 - Ludacris - Ho (Skit).wav
    CRC32: 002CA3D5
    Track 11: Ripped LBA 154769 to 167561 (2:50) in 0:10. Filename: C:\Users\User\Desktop\Encoding Folder\11 - Ludacris - Ho.wav
    CRC32: 4C60EEDA
    Track 12: Ripped LBA 167561 to 169998 (0:32) in 0:01. Filename: C:\Users\User\Desktop\Encoding Folder\12 - Ludacris - Tickets Sold Out (Skit).wav
    CRC32: 2FEFF03C
    Track 13: Ripped LBA 169998 to 189093 (4:14) in 0:15. Filename: C:\Users\User\Desktop\Encoding Folder\13 - Ludacris - Catch Up (Feat. Infamous 2-0 & Fate Wilson).wav
    CRC32: C86F9C2F
    Track 14: Ripped LBA 189093 to 211659 (5:00) in 0:17. Filename: C:\Users\User\Desktop\Encoding Folder\14 - Ludacris - Southern Hospitality (Feat. Pharrell).wav
    CRC32: 5E3E355E
    Track 15: Ripped LBA 211659 to 232493 (4:37) in 0:15. Filename: C:\Users\User\Desktop\Encoding Folder\15 - Ludacris - What's Your Fantasy Remix (Feat. Trina, Shawna And Foxy Brown).wav
    CRC32: BB9844E8
    Track 16: Ripped LBA 232493 to 254865 (4:58) in 0:15. Filename: C:\Users\User\Desktop\Encoding Folder\16 - Ludacris - Phat Rabbit.wav
    AccurateRip: Accurate (confidence 17) [Pass 1]
    CRC32: 0C29E4F2
    16 Tracks Ripped Accurately
      The safe option is to leave on 1024KB
      • poetryrocksalot
        • Jul 2008
        • 12
        Why is it safe to use 1024, wouldn't that be inaccurate from the detection test?
        The speed test is like 7000 ms without re-read and 7000 ms with re-read. I'm not sure if it was in MS units but I think it is.
          If you have a cache of 400KB then setting 1024KB would clear it, and I am unaware of any drive with a bigger cache than 1024. Even for drives with no cache it is safe to put in 1024.
          • poetryrocksalot
            • Jul 2008
            • 12
            No when I click on detect, it say 4 KB (2 Frames), it doesn't say 4000 KB or 400 KB.
            Questions:
            [1] Is 4 KB a bad cache size? Is something wrong with my DVD Drive? It's a laptop drive, are laptop drives low quality?
            [2] If I set it to 1024 KB, does it mean that the maximum cache size will be used? (Like read how drive speed has a maximum option)
            [3] If you mean 1024 KB will clear 400 KB, does it mean it will "set max cache size"? "set it to 0 or no cache"? or "something else"?
            [4] So is 400 KB the same as 4 KB? Is it a dBpowerAMP typo error? Are there any reasons why my drive read cache is so low?
              Trust me: set 1024 and forget about it.
