Ripping Speed (Oh no, not again...)
  • Kilmatead
    • Jul 2008
    I'm not having a problem, per se, this is more of an observational question.
    Are there some specific criteria (outside of ripping settings) which must be met before the drive kicks in to higher speeds? I realise the speed always starts out slow and builds as it goes (generally), but mine seems somewhat schizophrenic - always starting out at x6, and after one or two tracks will kick up to x33 or so, which is fine. Some CD's however, just refuse to ever go faster than x8 or so... these are new/out-of-the-case media, no scratches, no fingerprints, visually "perfect". Yes, ok, "visually" perfect doesn't mean much, but you know what I mean.
    Like I said, it isn't a problem, it's just really odd that one CD will take a normal 5-6 minutes (give or take) at full speed and the next will take 15 minutes. I assume there might be some small discrepancy detected, so the programme intentionally slows the drive down?
    One must suppress the inclination to give it a good smack, as one would an old television, when it's acting up. :smile2:
    Re: Ripping Speed (Oh no, not again...)
    Many drives are like that, they set a maximum speed based on the last track read quality.
