Volume Control?
  • javajeff
    • Jan 2006
    • 60
    Volume Control?
    Can dbpoweramp rip CD's to the same volume? What do you do to maintain an even volume with your collection? I have been playing around with mp3gain, and iTune's Volume Control in file properties. I do not want tracks to clip, so maintaining the best sound is important to me. So far, I have kept all files at ripped levels, but some albums are extremely low volume. Any suggestions?
    • 46198
    Re: Volume Control?
    Use the DSP effect volume normalize and apply Replaygain normalization.
    • javajeff
      • Jan 2006
      • 60
      Re: Volume Control?
      I do not really understand how it works. Should I just use the default settings? I think the max gain is set to 8. Will that clip tracks? I examined the tracks using mp3gain, and every track was at 89db.
        • 46198
        Re: Volume Control?
        As long as you have ReplayGain (track gain) selected there is no clipping as replaygain reduces the volume of all tracks relative to a certain level.
