Ripping speed (slow)
  • fb03er
    • May 2007
    Hello,
    I have Reference dBpoweramp Release 12.4, and I have a problem now.
    I was ripping with ~40x ripping speed, and was very satisfied with it.
    But now, I'm getting, at most, ~10x ripping speed, I haven't change any configuration or settings, and my drive seems to be working.
    What should be wrong?
    My drive settings, if helps:
    Ripping with drive 'E: [HL-DT-ST - DVD-ROM GDR8163B]', Drive offset: 102, Overread Lead-in/out: No
    AccurateRip: Active, Using C2: Yes, Cache: None, FUA Cache Invalidate: Yes
    Thanks in advance.
    Re: Ripping speed (slow)
    Read this and check: http://forum.dbpoweramp.com/showthread.php?t=15415
    • fb03er
      • May 2007
      Hello,
      I've checked, and what I've found:
      Primary IDE channel
      Dispositive 0, current transfer mode: ultra DMA, mode 2
      Dispositive 1, current transfer mode: DMA if possible, but it's not activated
      Secondary IDE channel
      Dispositive 1, current transfer mode: PIO mode (I can't change it)
      Any ideas?
        Read the bottom part of my link above, it tells you how you can fix it.
