Problems ripping with R13
  • Olaf101
    • Jan 2008
    Hello,
    I have always been a happy user of dbPoweramp until i installed R13 yesterday. I'm ripping to MP3 and regardless of what drive I use (LG-H58N or Plextor PX-716A) i jut get MP3-Files that have a size of 625 kB. When i rip to Wave, i get files of 44 kb. I tried different Communication Modes, but the problem remains. With R12.4 everything was fine.
    Any ideas?
    • 46198
    Re: Problems ripping with R13
    Make sure you have no DSP effects running.
    • Olaf101
      • Jan 2008
      I haven't even installed DSP Effects. I had when using R12.4, but i have removed them before installing R13.
      It looks like ripping seems to work. When the progress bar for the track reaches 100%, it switches to "Encoding 0%" and after a second goes to the next track. The resulting MP3 Files are those small files i mentioned.
        • 46198
        Run the program listed here to clear dBpoweramps settings:
        http://forum.dbpoweramp.com/showthread.php?t=13285
        They reinstall, activate AMG. Try ripping with the default settings.
        • Olaf101
          • Jan 2008
          That solved the problem! Thanks a lot!
