Accurate Rip - but poor quality
  • Mozart56
    • May 2008
    Hi guys
    I'm using the fully registered version of DBPA and maximum secure settings. When ripping a CD I get the Accurate Rip confirmation on all the tracks and the secure stamp, but when I play the file on my squeezebox I can hear an audible pop on one of the tracks that sounds like an error on transfer. I have re-ripped the track a couple of times and it is still there in spite of the accurate rip confirmation. I have also played the same CD via my old pioneer DVD player digital out into the same DAC that I run my squeezebox into and get no pop, so the CD is fine. Any idea what I'm doing wrong? Thanks in advance
  • bhoar
    • Sep 2006
    • 1173
    Re: Accurate Rip - but poor quality
    What codec and settings are you using? Have you tried to rip to a codec and/or modified the settings?
    -brendan
    • Mozart56
      • May 2008
      Hi Brendan
      I'm ripping to FLAC and using the standard secure and ultra secure settings. Flac compression is a Level 5 (medium) I think. I'm at work right now so don't have it in front of me. Is there anything more specific I should investigate? I was just surprised to get the accurate rip confirmation when there are obvious errors.
        Using c2 pointers as well? There exist some cds which are mastered badly which do have audible pops on the CD!
        Make sure you are not using any DSP effects (such as volume normalize).
        • Mozart56
          • May 2008
          Never use the DSP effects. Haven't tried the C2 pointers check yet, but thought that if it returned a success in accurate rip I wouldn't need too. It's definitely not on the disc as I don't hear it when I use a conventional player.
            A conventional CD player would effectively silence out any error on the disc, if the result is in accuraterip and it came from another person, with another disc, then it is possible a manufactoring defect affects all the discs, c2 pointers might detect such.
            • bhoar
              • Sep 2006
              • 1173
              Originally posted by Mozart56
              Hi Brendan
              Try ripping just the problem track to MP3 and then playing it on the ripping computer. Does the pop happen there too?
              -brendan
              • Porcus
                • Feb 2007
                • 792
                But even Ultra Secure mode will conclude that the rip is jolly good as long as it matches AccurateRip. Need to disconnect from the internet first, maybe?
                • Mozart56
                  • May 2008
                  Will try that.
                  Disc is Diana Krall's "Love Songs" and the track is track 7. Very popular disc that has been ripped many times, so I'm not certain that it is a manufacturing error. I've actually had a similar problem with a timing error, and it came up as a accurate rip. Re-ripping seemed to solve the problem for that error. Wondering whether accurate rip has defective results in it? Also not sure why my DVD player playing digital out would "silence" the defect. It is going into exactly the same upsampling DAC. Surely the digital feeds should be identical?
                  • bhoar
                    • Sep 2006
                    • 1173
                    Did you try my suggestion of ripping to an alternate codec, with alternate settings and playing back on an alternate platform? Just in case the issue isn't the ripped data itself?
                    -brendan
                    • Mozart56
                      • May 2008
                      -brendan
                      Hi Brendan
                      Will try that tonight. The squeezbox plays all formats so I'll try MP3 and see how it goes.
                      • bhoar
                        • Sep 2006
                        • 1173
                        Hi Brendan
                        Please try it on windows media player or itunes as well, just in case.
                        -brendan
                          Uncheck the AccurateRip option (Options), then the program will check the track on its own, not against accuraterip.
                          • Mozart56
                            • May 2008
                            Thanks Spoon. Semmed to have it finally working. Lesson here is to trust your ears and not accurate rip I also bought a cheap Pioneer DVR 213 to sit below my LG spinner. Going forward I might try both and see if there is any difference. The LG seemed to take forever to get it right. Cheers.
