Rip cd problem
  • ffm76600
    • Apr 2007
    • 168
    Rip cd problem
    Hi
    I use dbpoweramp 12.4 registered, secure mode, ultra secure mode (all parameters are 1), windows xp sp3 and ripping cd is very slow (ripping speed x4.5 max with a lg gdrh20N serial ata).
    I have :
    core2duo e8400, 3 gb ram
    Why is too slow ?
    Re: Rip cd problem
    Try a different CD and reboot windows (full shutdown). If it is still slow:
    • ffm76600
      • Apr 2007
      • 168
      Re: Rip cd problem
      I have always the same problem and the accurate set in on +102 :(
      My lg drive doesn't support C2 pointers, it's very strange !
      • ffm76600
        • Apr 2007
        • 168
        Re: Rip cd problem
        Do you have a solution ? :komisch9:
          Re: Rip cd problem
          Did you check the link Spoon posted about making sure your drive is still DMA?
          • ffm76600
            • Apr 2007
            • 168
            Re: Rip cd problem
            Yes, I have. My lg dvd player have the c2 support, I see that with nero infotool ! There is a software problem.
              Re: Rip cd problem
              It is nothing to do with c2 pointers (I do not think), to check the DMA of the drive you must look in 'Device Manager'
              • ffm76600
                • Apr 2007
                • 168
                Re: Rip cd problem
                Strange the first "ide primary" is on dma mode but not the second and the third "ide primary". Same thing for "secondary ide"
                • ffm76600
                  • Apr 2007
                  • 168
                  Re: Rip cd problem
                  It's ok now !
                  I uncross the c2 errors pointers...
