Ripper R13 - Problem with album art
  • stealle
    • Apr 2008
    • 42
    I'm using R13 to rip CDs to FLAC. For some reason I am getting a .jpg file of the album art for every FLAC file.
    I get a folder.jpg ... I want that.
    I get embedded album art in each of the FLAC files ... I want that too.
    I get a [tracknamehere].jpg for each FLAC ... I don't want that.
    I can just delete them. But, what setting did I trigger so I can undo it?
    Thanks!
    Re: Ripper R13 - Problem with album art
    Either the ID Tag processing DSP, or Options >> Meta Data & ID Tag options
    • EliC
      • 1175
      When using R13 and AMG + GD3, shouldn't you be getting multiple album art results? I always get only 1 and I am pretty sure its from AMG.
      • stealle
        • Apr 2008
        • 42
        I almost always only get 1. It seems like there was one CD that gave me 2. This doesn't have anything to do with my original question (which is fine by me), but if you are trying to assist with an answer to my question I think you mis-read or I wasn't clear enough.
        Spoon identified the problem. I had ID tag processing in DSP messed up. I tried to follow his advice in this thread:
        You can use the ID Tag Processing DSP effect, enable the input folder.jpg and export folder.jpg options.
        I accidentally set ID Tag processing to "[filename].jpg" instead of "folder.jpg". So it was creating an album art .jpg for every track. Meaning - when I ripped a CD the folder would contain about 15 .jpg files of the same album art image.
        All is well now that I have it set as Spoon suggested in the above link.
        • EliC
          • 1175
          no, mine is a separate question. also a problem with r13 and album art. When getting multiple premium lookups there should be multiple album art results.
            The highest resolution art is used.
            • stealle
              • Apr 2008
              • 42
              Oh I see. Yeah, I was wondering the same thing. It seems like you should be able to choose for yourself. With the largest being the default. The reason I say this is because I had one that had marker writing all over it. Another that looked ripped. So I have to go to amazon.com and look up the album and load that image instead.
              • EliC
                • 1175
                shouldn't you be able to use the scroll arrows and see the different arts available? Sometime they are wrong from one service.
                  It is a feature request for r14
                  • EliC
                    • 1175
                    Could we at least get the option to save the highest resolution art from BOTH sources automatically. This should be a small change not requiring changes to the gui or other major changes and could be implemented before a year plus in r14 and should even be doable for 13.1 or .2 I would imagine.
