Artist field not displayed/editing problem
  • aussie1
    • Apr 2008
    I have been using the CD ripper successfully for a long time. Recently encountered a problem in the display. The artist column is marked as a field to display. However, this column does not appear in the display.
    Further, if a select a single track and edit the artist in the Meta section. This change is applied to the artist field of all of the tracks.
    I tried uninstalling and reinstalling the program with no luck. Any ideas?
    Re: Artist field not displayed/editing problem
    The artist field appears at the top of the window. Click on a track then change the Artist field at the top to change only that track.
    • aussie1
      • Apr 2008
      Thanks for the reply. I'm aware that the artist fields is at the top. My problem is that if I click on a single track and change the artist in the top window, it applies that change to all of the tracks.
      It will not allow me to change the artist for a single track or a selection of tracks without changing the artist for all of the tracks.
      • Teknojnky
        • Dec 2006
        • 323
        click the compilation check box
        Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
        Want a random mode based on track and artist relationships?
        [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
        [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
        • aussie1
          • Apr 2008
          That works. Thanks!
          • CtrlAltDel
            My Compilation checkbox is greyed out - is it a registered-version-only feature?
              Yes, Compilation support is a Powerpack or Reference-only feature: http://www.dbpoweramp.com/db-versions.htm
              • ronaksf
                • Sep 2008
                What is the real purpose of the Compilation box, just wondering where I need to use it when ripping my CD's
                  Tells audio players that the album has different artists.
                  • CtrlAltDel
                    Interestingly, I popped in a CD today (The Original Rocky Horror Show) and it came up with artist fields for each track; I then swap it for The Best Seventies Album In The World Ever (no, seriously), and the artist fields have disappeared.
                    Most strange.
                      If the metadata provider(s) do not flag the disc a compilation there is nothing to stop manual selection and typing of artists.
                      • CtrlAltDel
                        So if I'm using the non-registered version:
                        1. if I enter a disc tagged by the metadata provider as being a compilation, I can edit the individual track artists, despite not having the registered version installed;
                        2. if I enter a disc not tagged by the metadata provider as being a compilation, I cannot edit the individual track artists;
                        Is that correct?
                          If the trial of Reference has ended then there is no access to set compilation manually.
