Speed Difference: Power Pack and Reference
  • Wallman
    • Apr 2008
    Is there any difference in speed between the Power Pack and Reference version in ripping? (Assuming using the same hardware)
    Re: Speed Difference: Power Pack and Reference
    If you have a multi-core CPU and are using Burst mode, very much so, yes. Other than that, no speed differences come to mind, but do note that Reference can also do Ultra Secure ripping. See other version differences here: http://www.dbpoweramp.com/db-versions.htm
    • Wallman
      • Apr 2008
      Thanks for the quick reply. I only have a single core chip and I've been ripping secure using the reference trial. CAn I assume Ultra is slower than secure?
        • 46198
        Yes
