Changing options resets ripping speed to maximum
  • matt_t
    • Feb 2008
    • 80
    My CD-drive will only rip if set to a low speed (I use 4x). However, if I change any options (tagging, you name it) without a CD being present in the drive at the time, it automatically defaults back to maximum. This is a bit annoying if I forget to set it back to 4x.
    Is there a way to make 4x (or any other speed other than maximum) the default?
    Re: Changing options resets ripping speed to maximum
    This doesn't seem to happen for me.
    What version of dMC (dBpowerAMP Music Converter) are you using?
    Bill
    • matt_t
      • Feb 2008
      • 80
      12.4 registered.
      To be slightly more precise - without a disc in the drive, maximum is the only option available.
        Certain CD drives can be funny rporting the speeds back, some need the disc in the drive, most do not.
