Tom´s lossless Audio Kompressor - Tagging?
  • umue
    • Mar 2008
    Hello,
    this is my first Message in the forum. I have registrated to the dBpoweramp Reference Version 12.4. I´m impressed of the number of codecs , which are supported. But one code (the new "TAk") I have integrated with the cli-encoder. It works perfectly, but I didn´t find an option to write tags in the compressed files. On "EAC" I used the software "WAPET" additionaly, but with dbpoweramps Cli-encoder Wappet doesn´t work.
    Please excuse my english, i´m writing from Germany.
    Re: Tom´s lossless Audio Kompressor - Tagging?
    Why does Wappet not work? can yo unot call it from the CLI?
    • umue
      • Mar 2008
      Hello,
      I can call it with the Cli-encoder, and I added the following string for the TAK Encoder:
      %d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" "C:\Program Files\Illustrate\dBpoweramp\encoder\CLI Encoder\takc.exe" -e -p2 -overwrite [infile] [outfile]
      There are no error messages, Tak-Files were created, which I can play in Foobar, but no tagging took place.
        We do not use %a for artist you would have to do:
        -t "Artist=[artist]"
        • umue
          • Mar 2008
          Thanks for your answer,
          I tried to change the command-string, but the problem resists. Probably my description of the problem was not complete. The Tak-encoder can not writing tags himself. For that I want to use the program "wapet". In another constellation it worked in the way I have posted first.
          Does the tagging with "wapet" work in the cli-encoder, or have I to use an external tagging program?
            Any of these wrapper programs should work as an external encoder.
