Accuraterip problem?
  • tjay
    • Jan 2008
    I've been having a problem..when I put a cd in the drive and open dbpoweramp at the bottom of the songs list it says "cd in Accuraterip" but when i go ahead and click on "rip" it just does the secure ripping not "accurate rip". I have accuraterip checked in the options.
    Can someone tell me what the problem is?
    Re: Accuraterip problem?
    After the rip, do you get a result from accurate rip, such as AR(25) or something with a checkmark or x? Because if the rip result doesn't match AccurateRip, it starts a Secure Rip.
    • tjay
      • Jan 2008
      Thanks LtData for your fast reply..
      Ok I get this: xAR(2)secure
      What exactly does that mean?
      Am I doing something wrong?
        That means 2 people disagree with your rip but dMC thinks it is secure. If all tracks are marked X AR(2) your CD is probably a different pressing which would have different checksums for the tracks.
        • tjay
          • Jan 2008
          Ok ..thanks for your help LtData...
          • vsaprissa
            • Aug 2011
            I'v got the dBPowerAmp 14.2 but when I insert any audio CD into my burner, a popup windows appears, telling me something about Accuraterip access. And I do it. Then a 2ยบ popup windows telling me something about a wrong key and since then I can not rip any CD Audio. In every track an "Error" appears. This happens with any audio cd I'll try to burn. What can I do? Thank you.
              • 46198
              Select 'Copy to Clipboard' on the error page, then paste the errors here as a message.
