New user, new poster, having some difficulty.
I've installed version 12.4 (trial version) on a machine running XP. When I load the CD ripper, I get a screen with a message saying "load audio CD" in the top left corner, together with a box saying "insert audio CD into:" with a drop-down box with two options, which are my (correctly identified) CD and DVD drives.
So it seems as though the program recognises my drives, but doesn't recognise there's a CD in there. Other programs will play the CD OK.
I've tried the advice on related threads, and my options are set to the Windows internal choice that seemed to work for some other people.
I've tried loading the program with a CD in the drive and without, uninstalling and reinstalling. I'm really not sure where to go from here.
Other info which might be relevant: the program is installed on an F drive, not the C drive. Would this make any difference? Other programs on the F drive work fine.
I've also had a parallel problem with EAC, where it doesn't recognise that there is a disk in the drive. I tried the advice on this thread about copying a dll file into the same directory. Again it seemed to work for others, but not me.
I'm a medium level computer user, definitely not a techie, and a complete beginner with this program.
Any advice gratefully received.
