Re-establishing a drive's offset?
  • LockSmithDon
    • Dec 2007
    I'm pretty sure I didn't complete the initial "key disks" exercise that AccurateRip prefers the first time you use it. Now it doesn't prompt for key disks anymore and I'm not comfortable it has the right offset in place. In other words, I'm not sure to believe if the "inaccurates" are real.
    Is there a way to get AccurateRip to make me go through that initial exercise again so I can be sure it is good to go?
    Don
    Re: Re-establishing a drive's offset?
    CD Ripper >> Options >>
    where it lists the drive offset click the reset button.
    • LockSmithDon
      • Dec 2007
      Thanks Spoon
      I assume that will reset the offset for all of the drives. I really only wanted to reset one, but it's not that big of a deal to do it again for all 3 drives.
      Thanks again
        Only 1 drive is resetted.
