Help with secure rip settings (newbie)
  • paddlefoot
    • Aug 2007
    • 11
    Hello,
    I am having a problem getting a cd to show up as ripped error free (I think). I am not a programmer or technician, so a lot of the settings are over my head. Do I have everything set up correctly? I want to rip a couple cds that have a few scratches on them. According to EAC my drive supports accurate stream, c2 pointers, and NOT caching. Whevener I try to have dbpoweramp detect caching it hangs and I am forced to close the program. Here are my settings.
    Drive: E: TSSTcorp -DVD+-RW TS-L632D
    Eject after rip: Not checked
    Ripping Speed: Maximum
    Spin-up Time: None
    Spin-down after: Default
    Sample offset: +6
    Read into Lead-in or Lead-out Communication: SCSI Pass Through (SPT)
    Prevent auto-run on all CD drives: Not checked
    Ultra Secure
    Minimum Ultra Passes: 1
    Maximum Ultra Passes: 8
    End after Clean Passes: 1
    Vary Drive Speed each pass: Not checked
    Individual Bad Frames
    Maximum Re-Reads: 50
    Set Drive Speed: Maximum
    Drive Read Cache: 1024KB
    Clear Read Cache with FUA: Not Checked
    C2 Error Pointers for Error Detection: Checked
    Unrecoverable Bad Frames: No Abort
    Interpolate Unrecoverable Frames: Not Checked
    Mark Track as Error if Insecure: Not Checked
    Secure Extraction Log
    Report Contents: Simple
    Write to File: Not Checked
    Add to Information Log: Not checked
    My rip status comes back as [COLOR=Red]X AR (20)[/COLOR] Check Mark (In Green) Secure
    Re: Help with secure rip settings (newbie)
    You might have a different pressing of audio cd to the one stored in AR.
    • paddlefoot
      • Aug 2007
      • 11
      Thanks for the quick response Spoon.
      One last question. Are my settings correct for when I am secure ripping?
        They look ok.
