Best Settings for Massive Rip
  • funkyblue
    • Oct 2007
    • 65
    Hello All,
    I am waiting to confirm the best way to rip my some 500 CD's with my Brand New Plextor Ultraplex 40x SCSI drive.
    Time is not an issue, just the security of the rip.
    Currently I am using R13 Beta.
    dBpoweramp Release 13 Digital Audio Extraction Log from Friday, December 28, 2007 8:21 AM
    Drive & Settings
    Ripping with drive 'H: [PLEXTOR - CD-ROM PX-40TS ]', Drive offset: 676, Overread Lead-in/out: Yes
    AccurateRip: Active, Using C2: Yes, Cache: None, FUA Cache Invalidate: No
    Ultra:: Vary Drive Speed: No, Min Passes: 3, Max Passes: 6, Finish After Clean Passes: 2
    Encoder: FLAC -compression-level-8 -verify
    Are these settings the best method or should I change Ultra Secure settings?
    I am coming from EAC. Also, how do I embedd the Album Art in each individual FLAC?
    Cheers
    Re: Best Settings for Massive Rip
    C2 is not used for that drive, apart form that it seems ok.
    • funkyblue
      • Oct 2007
      • 65
      So just unselect C2 and the rest of the settings are good?
      EAC reports the drive as using C2.
      CD Ripper now reads the cd 5 times without C2 selected. Is this an overkill?
        We do not support c2 with that drive model (a very old scsi drive).
        • funkyblue
          • Oct 2007
          • 65
          It might be old, but I just purchased a brand new one.
          I though C2 in the Ultraplex 40x was good?
          So are my settings good? Just unselect C2 and the rest is OK?
          Thanks Glad I purchased this program just want a bit more conformation.
            If using accuraterip it will only read once with a match.
            • funkyblue
              • Oct 2007
              • 65
              Can you please confirm my settings.
              Lots of my CD's will not be in Accuratetip database. Is reading the cd 5 times them not an overkill?
                If you are very keen (on good results) then reading 5 times is not an overkill.
                • funkyblue
                  • Oct 2007
                  • 65
                  Ok, thats fine
                  So my settings are perfect, just unselect C2?
                  Just want to confirm b4 I get started!
                    Yes
                    • funkyblue
                      • Oct 2007
                      • 65
                      Thanks, glad settings are good. Just wondering why dBpoweramp is not supporting C2 in the Plextor 40x and why ripping 5 times is considered necessary to get a perfect rip without accurate rip? Just seems a little overkill
                      Cheers
                      • csiron
                        • Feb 2007
                        • 33
                        If you really care about good results, I'd get a good drive with c2 support.
                        I recently completed the last of a 6,000-disc project that I started in February, and I can say that you'll feel much better and move much more quickly with c2 support.
                        • funkyblue
                          • Oct 2007
                          • 65
                          I want a drive that reads into leadin/out.
                          PX-40TS has great C2 support except for some reason it is not used in dBpoweramp. What drive do you recommend that has good C2 and reads into the leadin/out and is available?
                          I couldn't find such a drive and settled on replacing my PX-40 with another drive.
