read offset to zero
  • rodney_mckay
    • Dec 2007
    read offset to zero
    Question, how do I get the read offset to 0, and accuraterip will work? I want to load a EAC image in daemontools, and re-rip with dbpoweramp cd ripper. So i get nice metadata from AMG. Thanks for answering..
  • rodney_mckay
    • Dec 2007
    Re: read offset to zero
    I found a solution. I have manualy add the read sample offset (zero for a virtual drive) in my registery. Works great!
      • 46192
      You should let dBpoweramp find the offset, even for virtual mounted images.
      • Tigerman
        • Mar 2005
        • 157
        Easier said then done, I ripped 15 cd of which only one was useable. I need 3 of discs.
        So Rodney please tell me how you determined the name and driveletter in the register?
        "Happiness is nothing more than good health and a bad memory."
        Albert Schweitzer (1875 - 1965)
        • Tigerman
          • Mar 2005
          • 157
          Finally found 3 key discs that were accepted. Can mount cue/wav-file and use accurate rip.
          Next question (Not DBP ripper related): is there a way to mount individual tracks with the EAC Non-compliant cue-file? I tried 3 different programs for virtual drives, none of them accept the non-compliant cue-file.
          Alcohol 52% gave me an error: no start-index was defined before previous track.
          So maybe some editing would do the trick, I tried to add a INDEX 00 but to no avail.
          Also searched the web for a solution, but couldn't find something that worked.
          Some hints would be welcome.
          • Foamer
            • Feb 2009
            • 10
            Dumb question from a new user, but does the offset adjustment apply consistently to a particular drive model? It doesn't change from CD to CD, does it?
            Secondly, secure ripping appears to take much longer than AccurateRip. If a CD is in the AccurateRip database, do I need to run with SecureRip at all, and is not Secure Rip applied if an AccurateRip match is not found?
              • 46192
              CDs have pressing offsets. Drives have (usually) consistent offsets.
              dBpoweramp will smartly secure rip when it has to, or use AccurateRip when it can.
              • Foamer
                • Feb 2009
                • 10
                What settings does one use to first rip with AccurateRip followed by Secure if needed? When I set DBPA to secure, I started to see error reports in the rip log even when it was ripping on Secure. Too much longer, as well, and still had more errors?
                  • 46192
                  It will use AccurateRip first on secure always.
