Use Audio Info codec on multiple folders recursively?
  • belinea2010
    • May 2020
    • 17
    I have asked this question here as the Audio Info codec seems to be a batch codec (I may be wrong).
    I have multiple audio files in many different folders, one folder for each album or CD Single.
    At the moment if I want to use the Audio Info Codec I have to go into each folder, select the files,
    run the codec, save the information as a text file and repeat for every single folder. (I have 100's of folders)
    Is there a way of doing this recursively so that the codec looks at the audio file in each folder, gathers the
    information and places it in a single text file?
    This would be really helpful and would save so much time and messing about.
    • 46231
    Re: Use Audio Info codec on multiple folders recursively?
    Use Batch Converter to select folders.
