DSF -> FLAC conversion error
  • docles
    • Dec 2009
    • 12
    Hi
    I try to convert DSF files to FLAC using batch converter.
    here is the config of the conversion
    I got error immediatly.
    here is the message in the log
    Error converting to FLAC, 'C:\Users\cdoce\Downloads\Vanessa Fernandez - Use me (2014)\10 - Here but i_m gone.dsf' to '[origdrive]\10 - Here but i_m gone.flac'
    Error unable to open File '[origdrive]\10 - Here but i_m gone.flac' for writing. [clEncoder::BeginConversion]
    thanks for helping
    best regards
    docles
    • 46078
    Re: DSF -> FLAC conversion error
    Choose a real drive, your version of dBpoweramp looks quite old.
    • docles
      • Dec 2009
      • 12
      Well, I copied the files to another local folder (this was also the case before).
      Same error
      Error converting to FLAC, 'C:\Users\cdoce\Documents\Vanessa Fernandez - Use me (2014)\01 - Just wanna be with you.dsf' to '[origdrive]\01 - Just wanna be with you.flac'
      Error unable to open File '[origdrive]\01 - Just wanna be with you.flac' for writing. [clEncoder::BeginConversion]
      When using TEST CONVERSION it works.
      Thanks for helping
      Best regards
      docles
      • docles
        • Dec 2009
        • 12
        Same error
        Thanks for helping
        Best regards
        docles
        additionally, it works with WAV and MP3 format, it's all about the FLAC
          • 46078
          select the option above 'original folder'
