Can I use Arrange Audio to offset track numbers?
  • Hobizal
    • 42
    Using Windows PC. I have some multi-discs already ripped to FLAC. I now want to put them in one folder and rename the track numbers. Is this possible with the Arrange Audio function? Or is there another way to change the track numbers of all at once?
    • 1752
    Re: Can I use Arrange Audio to offset track numbers?
    You can store them in one folder and keep the original track number, if you use the disc number in the file names.
      • 44044
      If you need to change the track numbers you need to right click on the files >> edit id tags
