Help with viewing wma files
  • bigbten
    • Nov 2019
    • 11
    Can't view wma (windows media audio) files in Batch Converter. I can see them in Windows Explorer but not from the batch converter. I know I can convert from explorer but I want to do a bunch of folders at once. Can anyone help me?
    Re: Help with viewing wma files
    If you have windows install the wma codec from codec central, link on tool bar.
    • bigbten
      • Nov 2019
      • 11
      I had already loaded the codec for .wma files. I'm using Windows 10. I've figured out a work around. The trouble was opening the Batch Converter from the dbPoweramp Control Center. If I go into Windows Explorer and right click a folder that contains the CD albums I want to convert, all the subfolders and music files get checked and I can see the individual .wma files. Just a bug that needs to be fixed. Thanks.
        Perhaps you have 2 dBpoweramps installed to different locations?
        • bigbten
          • Nov 2019
          • 11
          Your right! I hadn't uninstalled the trial version. You folks should either tells us to or automatically delete it when we purchase it. Thanks anyway.
