help needed with conversion destination folder
  • DavidZ
    • Feb 2008
    Hi -- I have about 1200 folders, each named after an album, containing tracks in wav format. I want to convert all those tracks to flac and replace the wav files with them in the same folders (or in new folders that are named exactly the same). I experimented a little last nite, and got error messages with 2 of the 3 output options. The only one that worked was putting it back in the original folder. That's ok, but I would still have to manually delete the wav files. Can someone advise? Thanks! -- David
    • 45846
    Re: help needed with conversion destination folder
    You can try this (ensure you have a back up of the wave files as they are deleted):
    Add the DSP effect 'Delete Source File'
    and set the 'output to' as 'Existing Source Folder(s)'
    • DavidZ
      • Feb 2008
      Thanks, I'll give it a try.
