Batch converter max speed of i7 8700k vs. i7 9700k?
  • Smacker
    • Mar 2019
    Hi guys I wonder if any of you would happen to know how much of a conversion speed does a i7 8700k cpu with 16gb or ram would reach in conversion speed?
    I happen to have i7 9700k which does not have hyperthreading so its 8 physical cores. Music is on external usb3 hdd and conversion destination is a 3.5 wd blue hdd. The highest I got was around x450 speed sometimes less.
    Im wondering a lot if got better results if I went for i7 8700 with 6 cores and 6 ht cores making a total of 12 cores.
    1st world problems, right?
    • 44044
    Re: Batch converter max speed of i7 8700k vs. i7 9700k?
    What are you converting from and to?
    • Smacker
      • Mar 2019
      Mostly from flac to m4a.
        • 44044
        When encoding on your current system, all cores show 100% usage?
        • Smacker
          • Mar 2019
          Like this?
            • 44044
            That CPU graph perhaps averages out to 75%, a faster CPU will not help, the HDD is the slow part.
            • Smacker
              • Mar 2019
              are you sure? even if there was hyper-threading involved which could do 12 songs at the time the overall speed would still be pretty much the same?
                • 1752
                If the cpu would have been the limiting factor, you would have seen a cpu usage nearly at 100%.
