Anyone Running Batch Converter on a Synology NAS ? ......................
  • Cut-Throat
    • Feb 2011
    • 24
    Wondering if it is possible to run the Batch Converter on a Synology NAS .... That is where my Music is stored, and I could do this remotely as well.
  • timster67
    • May 2014
    • 210
    Re: Anyone Running Batch Converter on a Synology NAS ? ......................
    Only if you have a network drive setup on your PC/Mac so you access the music files from there. But only wired, if you try it wirelessly it will be slow and likely overload the WiFi bandwidth.
    • Cut-Throat
      • Feb 2011
      • 24
      Thanks for your reply... But either I did not understand you or you did not understand me.... I have a PC on my Network and have run the Batch Converter there on the Music Library that is stored on the NAS... And the speed is fine. What I was asking about is there a Linux version of the Batch Converter that could actually reside and run on the Synology itself?
      • timster67
        • May 2014
        • 210
        If you have a gigabit switch then the speed would be fine. I'd be surprised if it's ok over WiFi though.
        In answer to the question, no there isn't.
        • slardy
          • Jan 2014
          BatchConverter does not see my NAS (WD MyCloud). What is the problem?
            • 1752
            Did you assign a drive letter to the smb share?
