MacBook Pro 2018 6 cores 12 threads, batch converter using only 8
  • 3rik
    • Oct 2010
    • 36
    Hello,
    Just got my MBP 2018 yesterday. I thought the Batch Converter would use all 12 cores when converting.
    To my surprise, only 8 on 12 are used :(
    Is it a bug or dBpoweramp's limit ?
    Eric
    • 1685
    Re: MacBook Pro 2018 6 cores 12 threads, batch converter using only 8
    Under settings / converter:
    Limit conversion threads to: [ ]
    The default value (when nothing is set) is 8. You can override it to anything you like to raise the limit.
    Note that dBpoweramp will not use more threads than the number of detected hardware threads regardless of this.
    • 3rik
      • Oct 2010
      • 36
      Thanks. I've given a try with 12 but as soon as I close the settings window, then re-open it to check, nothing is written (so 8 is max).
      Either I don't write it how it should be, either it's a bug :'(
      Eric
      • 3rik
        • Oct 2010
        • 36
        Hello,
        Could you have a look at this please, so I (we) could use all (our) available cores in Batch Converter ?
        Eric
          • 1685
          Indeed doesn't work as it should. Fixed version (beta) will be up shortly. Sorry about this.
            • 1685
            New beta posted-
