batch convert: merge .wav audio and .mp3 tags?
  • ultradB
    • Oct 2017
    Hello - I have a specific use case to ask about.
    I have a large set of .wav files that need to be batch converted to FLAC. That's extremely easy to do in dBpowereamp.
    The challenge is that the metadata needed for the resultant FLAC files resides in same-named .mp3 files. So, for example, for each audio track, I have:
    spoon_IndaHouzz.wav (source for audio)
    spoon_IndaHouzz.mp3 (source for tags)
    Is there a straightforward, automated way to get dBpoweramp to transcode the .wav files to FLAC while applying the tags from the same-named .mp3 file for each track?
    Re: batch convert: merge .wav audio and .mp3 tags?
    No, the tags would need to exist in the wav files prior to conversion, or you would need to copy/import from the mp3 files to the flac files, post conversion.
      Convert the mp3 files to FLAC and include the DSP effect 'xml writer' and have it write the tags out to a file (all default options).
      Then convert the wave files to flac and include the DSP Effect 'xml reader' it should import the xml previously written.
      • ultradB
        • Oct 2017
        Thank you for these workarounds.
        I will need to process large volumes of files in an ongoing fashion, so doing double-transcodes will be a doubly heavy process.
        I posted this question generally and got an interesting response here as well: http://tinyurl.com/ybdnevjw
        What do you think about being the first transcoder to include this functionality built-in to the GUI?
          There are many ways to accomplish what you ultimately want, but you were asking if there was a straightforward, automated way to do this and sadly, there isn't.
          Personally, I would:
          1. Convert the wav files to flac.
          2. Open the mp3 files in MP3Tag and export all the tags.
          3. Open the flac files in MP3Tag and import the exported tags.
          4. DONE.
