DSF batch conversion to 96 or 88.2 kHz ?
  • awesome
    • Aug 2017
    As I'm fairly new in ripping my SACD's to DSF and then converting them to FLAC, I read that I should stick to 88.2 kHz and not 96 kHz when doing this.
    A) Is this correct?
    B) If so, can this be done with dbPoweramp? How should I go about this?
    Re: DSF batch conversion to 96 or 88.2 kHz ?
    A) No, DSF to Flac goes through a frequency transformation, there is no benefit of 88KHz over 96KHz.
    The codec advanced options section allow the final frequency for DSF conversions to be set (dBpoweramp control centre >> advanced codec settings).
      Are you aware that you can't rip the hi-res layer of an SACD with dBpoweramp and only the CD layer (16-bit, 44.1kHz), if the SACD is a hybrid SACD?
      • awesome
        • Aug 2017
        Yes, I'm aware. I'm ripping from my Oppo BDP-103
        • awesome
          • Aug 2017
          Found this in another forum:
          The sample rate of SACD is 2.8224 MHz which is evenly divisible by 44.1K, 88.2, 176.4, 352.8, etc. The conversion math is simple. Converting to rates that are not even divisors is messy.
          So I chose 88.2
            This is flawed information, if you had a CD track which was 44KHz you would not simply convert to 22KHz because it was half the value (by skipping values or averaging 2 values) as this would create horrible aliasing of the signal.
            dBpoweramp has a high quality resampler which does not introduce audible aliasing. See:
