Batch Converter Doesn't Keep Track Number Format I Have Set
  • bbildman
    • May 2007
    • 9
    Normally I set the track number as xx/xx, after the convert, the track number is left as just x or xx. Is there anyway to make sure during the conversion process, the track number setting I have enabled remains so I don't have to go back and redo the numbers??
    • 46230
    Re: Batch Converter Doesn't Keep Track Number Format I Have Set
    Which format are you converting to? some id tag types the track number is held internally as a number and cannot be set as xx/xx
    • bbildman
      • May 2007
      • 9
      Hi, I use "Tag&Rename" to set the track numbers, it has different options, "format track * to":
      x;0x,00x;xx/xx;xx and Autofill,which has the options for normal x or xx/xx.
      The reason I want an xx or xx/xx format is many times I use this for books or music which have more than 10 chapters or songs. On the little mp3 player I use, if there is a first chapter (1) AND a tenth chapter (10), the mp3 player will order them with the first track * as 1, then 10, then 2, 3, 4, etc::
      1
      10
      2
      3.
      If I have the track numbers formated as either 0x, xx,or xx/xx the mp3 players orders them perfectly. When I use batch converter, the track *s are always formated as x::
      1,2,3,4, instead of 01,02, 03 etc.
      Any help appreciated. If I have not been clear, tell me which part you do not understand. Thanks
        • 46230
        We do not have the option to pad track numbers as you require, sorry.
        • bbildman
          • May 2007
          • 9
          Ah, thanks Spoon, just the answer I was looking for. I guess I will run my Tag&Rename program AFTER I convert the files.
