conversion from flac to ogg.
  • dechicom
    • Jun 2017
    Using batch converter flac to ogg got :
    Error converting to ogg vorbis (aoTuV SSE3), '\\DLINK-05955B\Volume_1\mydata\multimedia\music\ogg\classi cal\Wolfgang Amadeus Mozart\Zauber Flöte Part II Obras completas, Vol. 9 (Disco 42)\20 Wolfgang Amadeus Mozart - Arie; 'Ein Mdchen oder Weibchen'.flac' to '\\DLINK-05955B\Volume_1\mydata\multimedia\music\ogg\classi cal\Wolfgang Amadeus Mozart\Zauber Flöte Part II Obras completas, Vol. 9 (Disco 42)\20 Wolfgang Amadeus Mozart - Arie; 'Ein Mdchen oder Weibchen'.ogg'
    Error writing audio data to StdIn Pipe [clEncoder::EncodeBlock]
    When using conversion from flac to mp3 it works fine.
    Might be a little bug in the ogg lib.
    Found nothing to fix it!
    • 46171
    Re: conversion from flac to ogg.
    Try converting to a local file on your computer, not the network share (bring source file to your computer, and convert to a local folder).
    • dechicom
      • Jun 2017
      Thank's, I'll try it.
      About functionalities (this is another problem):
      I have a folder (ogg/classical/) that contains a hierarchy of subfolders. The leaf-folder being a cd album.
      These subfolders contain ogg files or flac files.
      I want to convert the whole thing to ogg and install it later on my smartphone withe only ogg files.
      I have two solutions:
      -- "overwrite" the source folder after making a copy. In this case I still have flac files. I don't need them any more.
      What can I do to suppress automatically the flac after the the ogg has been generated?
      -- ask batch converter to output in a new folder. In this case no copy of the path bellow the source folder is done.
      Does the softaware allow such a functionality with some keyword?
      Also is it possible to simply copy the ogg files that don't need to be converted?
        • 46171
        If you want to remove the Source Files (flac in your case), use the DSP effect 'Delete Source File'
        Note you should not normally delete your lossless files.
