converting 24-bit to 16-bit and also FLAC to AAC/MP3
  • Rannoch
    • Jan 2015
    A couple of questions.
    1) Trying to convert 24-bit flac to 16-bit flac using batch converter.
    Settings ...
    Encoder: Lossless Level 5 (default)
    tick box "After Encoding Verify Written Audio"
    DSP Effects/Actions ...
    Resample frequency="44100"
    Bit Depth depth="16" dither="tpdf"
    Ran conversion, and used Perfect Tunes to check AccurateRip and get message "Cannot Check: Track Different Length Than CD Original". Is that what I should expect.
    2) Using Dbpoweramp, I have ripped all CDs to 16-bit FLAC. I have read that it's fine to store in FLAC, but if using any portable device or any player does not play FLAC, convert to AAC/MP3. AAC is said to be better quality than MP3 at same bit rate, in order to check which would be the more sutiable, what are the best conversion settings for both.
    Thank you for any help.
    Re: converting 24-bit to 16-bit and also FLAC to AAC/MP3
    Settings ...
    Yes. Converting a 24-bit flac to a 16-bit flac will not give you a bit-perfect file copy of the corresponding track ripped to flac from the 16-bit, 44.1kHz audio CD, which is what is contained in the AccurateRip database.
    I suggest you take a favourite CD, experiment with the settings, converting to both AAC and MP3 and then listen to the results on your portable player.
    • Rannoch
      • Jan 2015
      Thanks mville for your advice. Much appreciated
