Baatch conversion is not taking album art across properly
  • JOK
    • Jan 2017
    Hi
    my very first time ever using a forum so forgive me if I breach protocol etc. I have just converted my files from iTunes WAV format and used dougscripts to embed artwork. I am just in the process of converting to FLAC and sending the new files to my Aurender server.
    What is happening is that the artwork that comes across is the same for all files as the first one copied. Obviously I am doing (or have done) something wrong.
    is there anybody out there that can offer a reason and/or solution please.
    regards
    john
    Re: Baatch conversion is not taking album art across properly
    not sure if dbpa can read embedded art in a WAV file (maybe it does). I assume you've set up the DSP in the conversion screen with "ID TAG PROCESSING" and then click on "manipulation" tab, then setup what you want to have happen to album art??
    EDIT: and something simple, but important. You've checked to see that a player (other than itunes) sees these files and they have correct album art. Maybe something like foobar2000. Opening them in itunes is not a test, as itunes has its own internal database for these files containing the album art.
      I am quite certain that these wave files have no art embedded into them. Check this using a different tool.
