Flac to MP3 conversion and retaining artwork
  • mombasa123
    • Dec 2016
    Apologies if there is an answer to this already - I couldn't find :(
    So i have converted all my flac music w/i embedded artwork to MP3. All looked fine in that the artwork seemed to be retained/embedded in the MP3 files. MusicBee and DBPA definitely seeing the artwork.
    I then added the MP3 files to iTunes but the artwork is not showing up. MP3Tag can't see either. Digging a bit more it seems that the conversion didn't embed the artwork in ID3v2 (empty) :(
    How do i get DBPA Batch Converter to do that? Am happy to reconvert it all again. Do i use the ID Tag Utility codec somehow while converting?
    Thanks!
  • mombasa123
    • Dec 2016
    Re: Flac to MP3 conversion and retaining artwork
    Found the answer I think. Will try tonight
