The processing of the Programmable Action pair [IFMULTI] and [IF!MULTI] is failing in Batch Converter (but works in CD Ripper).
First, without ticking the Multi-Disc box, the correct output is shown as 'XXX not compilation'
However, upon ticking the Multi-Disc box, the Example output does not change -- error.
To demonstrate a working Programmable Action, here is what happens with [IFCOMP] and [IF!COMP]:
The Example output is correct.
Please investigate why [MULTI] and [IF!MULTI] are not evaluating correctly in Batch Converter -- it's acting like [IF!MULTI] is ALWAYS true and [IFMULTI] is NEVER true.
