Volume Normalise not working - Release 2025-12-24 (1)
  • EricH
    • Jan 2026
    Mac OS Monterey, trying to batch convert my library to FLAC 24bit, Mono, 48kHz normalized to EBU R128 (track gain) with a target of -12LUFS. DSP effects are set in that order, the first 3 work, volume normalize does not. I tried to save to different folders (including overwrite) to no avail. I end up with files at -21 to -13 LUFS. I do the same thing in RX 11 and it comes out fine. I have over 10000 tracks to process and RX batch window does not allow saving source path which means I would have to go through each artist and album folder individually. Anyhow not the issue, any idea why dB batch converter failing LUFS normalization ?
    R128 is based on average percieved (by the ear) loudness, not peak, how are you detecting the files are -21 to -13?
    To be 100% certain it is not working, convert one try with and without Volume Normalize to lossless (two different filenames), then convert those two files together to [Calculate Audio CRC], if the CRCs are the same then the loudness did not change.
    • EricH
      • Jan 2026
      Hi Spoon, thanks for your reply. As I mentioned I have iZotope RX, I ran the files converted with dBpoweramp through RX loudness control module and got integrated LUFS measurements ranging from -21 to -13. I converted the same original files with RX loudness control module and got consistent target level of -12 LUFS +/-0.5 as well as -1dBTP. I also ran the dB converted files through metering plugins (Insight 2 and Waves LM)and the readings are equally inconsistent.
      Also, I can tell by listening to them they don't have the same average loudness.
        Do the test please to see if the volume change is being applied.
          The "audio CRC" test mentioned earlier to be specific.
