batch converter - apple lossless - i tunes help
  • grahams
    • Feb 2016
    Please can you give me advice. I am using mac version of db poweramp and have ripped my cd's to Flac. I now wish to convert to apple lossless and put into my iTunes library as easily as possible.
    Please can you advise me (in simple terms)how to do this?
    Many Thanks
    Graham
  • pacoinmass
    • Feb 2016
    • 30
    Re: batch converter - apple lossless - i tunes help
    Graham,
    See following thread: https://forum.dbpoweramp.com/showthr...-bit-to-16-bit.
    It contains reference to two other threads. Process rather simple.
    There's also a way to keep the same file structure...using one or more "[TRIMFIRSTFOLDER]string" commands, depending on your own file structure if you want to keep the Apple Lossless files in separate folders than the original flac files. Experiment but make sure you have the originals someplace safe.
    pacoinmass
