Flac 24 bit to 16 bit
  • Sugar Magnolia
    • 106
    I've got some 24 Bit flac files that I would like to flip to 16 bit.
    Can I do this with Batch Converter? When I set up a flac to flac conversion there is no option to set the bitrate.
    Is it possible to do this, and if so, how?
    Do I need to convert to another format, then back to flac?
    Is there a third party utility I should use for this?
    Thanks, Pete
    Re: Flac 24 bit to 16 bit
    Use the DSP effect 'Bit Depth'
    convert to a different location so as not to overwrite the original.
    • Sugar Magnolia
      • 106
      Excellent. Thank you very much.
      • Sugar Magnolia
        • 106
        Do you have a recommendation for "Dither"?
        It looks like to go from 24/96k to 16/44.1k I'll need both the "BitDepth" and "Resample" DSPs.
        Does it matter which order the DSPs are listed in the "DSP Effects/Action" window? In addition to those, I am also running "ReplayGain" and "ID Tag Processing" which are listed ahead of Bitdepth/Resample.
        • Sugar Magnolia
          • 106
          Found these answers (Triangular dither and Resample before bitDepth) :
          Does it matter which order the DSPs are listed: RG, ID TAG, Resample, BitDepth?
            Bit depth should be last.
            • cloz
              • Aug 2020
              Hi Spoon -
              I have some huge 24/192 FLAC files that I'd like to take down to 24/48 ALAC files to put on iPhone. 24/48 seems to be the max for iPhone without using a DAC.
              Is there a recommended path / order to do this? Do I need to dither if it is staying as 24bit? Do I need any of the DSPs?
              Thank!
              C
                You would just use Resample, no need to change the bit depth if already 24 bit.
