WAV encoding randomly dropping 60-90 seconds of audio
  • Eric Seaberg
    • Apr 2010
    • 37
    We produce an international radio program and have been using dBpoweramp exclusively for our encodes. We've recently been having issues where 60-90 seconds of audio is randomly dropped around 15-minutes into the program. All we're doing is converting 48K/24bit files to 48K/16-bit using dither in DSP effects. We are now having to confirm every transcoded file before going on to the next encode. Would it help to export any logs or configuration files? This is VERY RANDOM!
    Eric Seaberg - San Diego
    [I]A.E.S., S.M.P.T.E., S.P.A.R.S.[/I]
    What are you encoding from?
    • Eric Seaberg
      • Apr 2010
      • 37
      Sorry it took me so long to get back... I'm transcoding from 48K/24bit WAV, using dithering DSP, and saving as 48K/16bit WAV. The error is totally random but most always mutes a window ending at 16:00 minutes into the program with a start point of 60-90 seconds prior. I may do this transcode on as many as 50+ files at a time, but the ones with the problem come from a specific folder.
      We've been doing this process for many years and just recently started having the problem. Once the 16bit version is done, we run a script that does level check and automatic drop of 6dB overall (for peaks) then converts to MP2 with name change and cue-chunk, all based on meta data within the original WAV file. MP2s are then submitted for broadcast and/or satellite distribution.
      At this point, I'm doing a manual check of each file in the process... sometimes there's one or two, and other times none. Very odd.
      Anything I can look at? Encoding in the first stage is done on a Mac Studio M2 Ultra 64GB RAM running Sequoia 15.5. Stage two conversion to MP2 with metadata is done Windows Virtual, but when we see the error it comes from the first stage Mac encode.
        It is possible it is hardware at fault, if it was a coding issue then the issue would be:
        wide spread, and reported many times in this forum
        repeatable
        • Eric Seaberg
          • Apr 2010
          • 37
          I certainly assumed that, and have suspected issues with our Virtual Servers. I'll circle back with our IT guys to see what they think. They had been talking of building new devices anyway... thanks for the reply.
          • RiroRiro
            • May 2025
            • 9
            I had a remarkably similar issue. I was using paid VST plugins in my batches... and for some reason they forget that I've typed in the activation code periodically. Thus, they revert to trial version... which in my case, caused a deafening blast of white noise in the file at random intervals... but always :30 seconds long. I realized what was happening when I opened the plugins in my DAW to try to replicate the problem... and when opening the plugs they bombed me with the "pay now or die" window.
