R15.3 Mac, batch converter : more than 1 hour after converting before it really ends
  • 3rik
    • Oct 2010
    • 36
    Hello,
    I've once again used batch converter to converts 9316 FLAC to OGG, and it has a strange behavior (was the same with Mac R15.2) : When encoding is finished, Hard drive keep spinning for more than 1 hour before the batch converter displays the close button, just like if it keeps on converting...
    Sorry for my bad english, I can't find better words to describe the situation.
    This is really annoying (took 3h40 to convert, and "at the end" I have to wait again for more than 1 hour for the close button.
    Regards,
    Eric
    Re: R15.3 Mac, batch converter : more than 1 hour after converting before it really e
    Did you use the DSP Effect ReplayGain?
    if so it was writing the album gain.
    • 3rik
      • Oct 2010
      • 36
      Hello,
      I've tried another batch converting without RG, and the I have the same problem. It's very annoying.
        What DSPs are you using, if any?
