A little help with a folder structure condition?
  • TomBomb
    • Oct 2015
    Re: A little help with a folder structure condition?
    Actually, I just managed to make it work!
    This is what I used:
    [album artist]\[album]\[IFVALUE]disc,[Album] Disc [disc]\[][track] - [title]
    Thanks for the help, though, I probably wouldn't have found it I wasn't experimenting with your ideas!
      Originally posted by TomBomb
      Thanks guys,
      I tried both options, but unfortunately, neither of them works. The first one doesn't create a disc folder, and the second one always creates one (with no disc number) :(
      Sorry, I have just noticed you create Album\Album, Disc (a folder within a folder):
      [album artist]\[album][IF][disc_total],=,1,,\[album]_COMMA_ Disc [disc][]\[track] - [title]
      So I did not check and see the sub-folder. So, as long as Disc is populated, the Naming string above IS working for me.
        Yep, that looks good too.
        ... as has been pointed out though, it DOES rely on how you populate the Disc tag, which in this thread, is unclear (pre-ripping and post-ripping).
          In CD Ripper, it doesn't matter much because once the discs are ripped I change these values. If there is only 1 disc in the album, then these values are empty (I remove them). If there are several discs, then there will be the disc number and the total number of discs.
          I don't think this is a good idea at all.
          Server/player software often references the Disc tag. Your Disc tags are not consistent and there may be repercussions later, with other software.
            One other thing to be aware of is the maximum folder/file path length, which in windows is limited to 260 characters.
            Your nested Album folder concept may give you a problem with long Album names.
            Example:
            The Rise And Fall Of Ziggy Stardust And The Spiders From Mars (30th Anniversary Edition)\The Rise And Fall Of Ziggy Stardust And The Spiders From Mars (30th Anniversary Edition), Disc 2
            is 185 characters long, so there is not much room for error here.
            There is the [MAXLENGTH]maxlength,string[] function, to help with long strings.
