dBPowerAmp for Mac : problem (?) with EBU R128 ?
  • 3rik
    • Oct 2010
    • 36
    Hello all,
    I use R15.2 for Mac. I've re-encoded all my FLAC library (to FLAC of course) with EBU R128 loudness stuff (I've let -23dB).
    It seems to work but all my album don't have the same loudness as I thought it should be...
    I thought that EBU R128 would make all album play at the same loudness (I use replaygain album).
    Is this normal or is it a dBPowerAmp issue ?
    I thank you fior your help
    Regards,
    Eric
    • 46141
    Re: dBPowerAmp for Mac : problem (?) with EBU R128 ?
    The replaygain DSP effect only writes ID tags which a compatible player can use to set the volume. What is your player?
    • 3rik
      • Oct 2010
      • 36
      Thanks for your answer
      I use Music Player Daemon (it supports RG), and Cantata as a client to listen to music
        • 46141
        Try as a test:
        http://sbooth.org/Play/
        Then you can be sure the replaygain is applied (you might have to configure it).
        • 3rik
          • Oct 2010
          • 36
          Thanks Spoon. It works fine with Music Player Daemon now that I've set it the right way.
          I have another question : I assume that RG value is set to 89dB, right ? The problem is that audio too quiet now. Is there a way to change this value in dBpowerAmp R15.2 for Mac please ?
          Regards,
          Eric
          Edit : I'd like to set it to 95 dB
            • 46141
            It is your -23db, if you set to -18 for example.
