Re: Preserving folder layout, not same as I'm seeing in forums
I'm glad you caught that....sorry for any confusion.
Definitely...this is a relatively common operation, since many people make alternate versions of their music library (for portable devices, backup, etc.) I assume that's why dBp has naming elements for copying the structure of an existing library. While we haven't nailed down the cause of your issue...yet, there's undoubtedly a solution.
Yeah, you're right...that'll get really old doing that many albums manually. I really think this can be worked out and you'll be able to get through them without all that extra work.
So let's say you have your original files....C:\users\davidrubenstein\Music\Aerosmith \Toys In The Attic
When you set are setting up the conversion for these files, what exactly are you putting in the "Folder" section? And what do you want the "top-level" folder to be in the new location? (i.e., should it start with the \music level, or lower, at the \artist level? Or something else?)
I've solved this with a little work-around, although in all honesty, I have to believe what I'm trying to do is extremely common and a solution should be found for what we've been discussing.
Anyway, my workaround, which worked fine with the small sample-size of folders I've copied over to test this string throughout this craziness, is to use [origpath]\[origfilename], and then to simply move the actual "album" folders three levels up, and then delete the empty "users", "davidrubenstein" and "music" folders, leaving the albums, which seem to only be copied over intact using only [origpath]\[origfilename] convention.
It worked fine doing this with a small sample-size, it will obviously be much more involved with 1,000 albums that I'm converting, but until the code is sourced correctly I can't think of any other way, though this is hardly the most efficient way.
Let me know your thoughts guys-
-D
-D
