R15.1 Bug: Audio Properties and WMA>WMA conversion corrupts long Track string
  • chrisjj
    • Nov 2008
    • 300
    E.g.
    Audio Properties
    Conversion
    Note: Track is stored as WM/TrackNumber, type WMT_TYPE_STRING
    The WM/TrackNumber attribute contains the track number of the content. This attribute is 1-based.
    Re: R15.1 Bug: Audio Properties and WMA>WMA conversion corrupts long Track string
    Track is the track number, ie 1/10, it should not be storing a value over 4 billion.
    • chrisjj
      • Nov 2008
      • 300
      WMA track number is a string and does not limit values to below 4 billion.
        It does not make sense, it is like putting "The crazy brown fox, jumped over the lazy dog" as a year value, then saying it is a bug because it is not preserved during conversion. Internally we standardize tags, tags which are way outside of the standard are likely to not be preserved.
        Putting a track number of > 4 billion, might even crash some players, because they not expect it.
        • chrisjj
          • Nov 2008
          • 300
          Sure it makes sense. It is a track number.
          Not at all. "The crazy brown fox, jumped over the lazy dog" is not a valid year. 0000863720712012 is a valid track number.
          This value is not way outside the standard for the format in question. As I said: Track is stored as WM/TrackNumber, type WMT_TYPE_STRING http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx
          If you are restricted to some proprietary 'standard' that cannot handle the standards of the file formats and hence causes this corruption, then please declare it and its limitations.
            If we had a WMA >> WMA only converter I would agree with you, however we do not.
            I have never seen a track number as you describe, track number is there to indicate the position on a disc.
            • chrisjj
              • Nov 2008
              • 300
              dBpa WMA > FLAC suffers the same corruption: http://i.imgur.com/cVECenx.png
              Now you have.
              If dBpa was only for tracks ripped from CD, it surely would not support tracks number up to 1000000000. It does. Many users have gone beyond CDs.
