RG Batch Conversion
  • auldyin
    • May 2013
    • 27
    RG Batch Conversion
    Apologies if this has been asked before......
    Should I remove all RG tags from files prior to batch conversion to the new standards?
    • 46230
    Re: RG Batch Conversion
    Replaygain tags are automatically dropped if you are converting.
    If you want to update, simply install the [ReplayGain] utility codec (from codec central) and convert all your files to this utility codec to have new gains calculated.
    • auldyin
      • May 2013
      • 27
      Thanks Spoon
