Mass scheduled conversion of FLAC to AAC (CLI?)
  • sprogger
    • Aug 2012
    Team
    Apologies if this is the wrong section
    I have a large (1300 albums) FLAC collection located on my media server. I have scheduked a regular backup of this library to my main server.
    I am also an apple iphone user and therefore require an AAC (m4A) copy for Itunes ... In the past I have used dbpoweramp to manually convert new FLAC albums into AAC (laborious process)
    I was wondering .. Is there a newbies guide on how to automate a dbpoweramp conversion such that it will run regularly to produce the AAC library? (assuming I use Windows Schedular)
    What I am looking for is (I assume) the format of the command line that I need to imbed in the Windows task schedular..
    Cheers
    Sprogger
    Re: Mass scheduled conversion of FLAC to AAC (CLI?)
    It is not possible to automate, however you can use Batch Converter, click your source folder, click Convert then when the overwrite page shows, click 'no to all' and only the new files will be written.
    • sprogger
      • Aug 2012
      Many thanks for the response ...
      Two questions ..
      First ... does the overwrite function have any intelligence in it? (does it only check if the folder/file exists or does it do date/time/CRC check)
      Second .. I would imagine that there are many users of dbpoweramp who are running two libraries .. one lossless (flac, wav etc) for home sound systems and the other lossy for mobile devices (aac, mp3 etc)
      Is there any requirement on future releases for scheduled batch conversions to be made available?
      Cheers
      Sprogger
        Overwrite checks existence of the file.
        There is always the possibility of such an addition.
        • sprogger
          • Aug 2012
          Thanks again
          So here is my suggestion (for what its worth) ..
          How about include an option on the batch converter menu that allows export of the executable command and parameters chosen to a flat file> (.bat)
          This could then be executed using whatever scheduler users choose (windows, linux etal)
          Is there somewhere illustrate collects user requirements?
          Cheers
          Sprogger
            The wishlist section of this forum.
            • sprogger
              • Aug 2012
              Many thanks for your guidance .. added to the wishlist section.
              Cheers
              Sprogger
