Settings Override (Control Point Specific) - Known Control Point List
  • JasHDahi
    • Jul 2012
    • 37
    Is there a way to clear this list to help identify latest connections/versions?
    Ultimately I want to customise individual control points' handling of artwork resizing, for example my Cyrus Stream remote has a limit while BubbleUpnp does not.
    Any tips on the scripts to achieve this too would be great.
    Cheers
    Re: Settings Override (Control Point Specific) - Known Control Point List
    Where Asset writes its configuration files (for Linux look at the help as each platform is different) there is a file:
    KnownControlPoints.txt
    Delete it.
    • JasHDahi
      • Jul 2012
      • 37
      Brilliant thanks that worked.
      Is there a reference for the various overrides/scripts available?
        Section 'settings override'
        • JasHDahi
          • Jul 2012
          • 37
          Thank You
