Asset Wifi problem
  • Taximan
    • Nov 2020
    • 8
    Asset Wifi problem
    I am using Asset UPnP server to connect my Cambridge Audio NP30 with my Mac. I am using the Cambridge Connect app on an iPad to control the NP30.
    Everything was working great for months. Last week I had my internet service upgraded, and new network and password. I no longer see anything listed in the library of the Cambridge app.
    Any solutions for Asset? thanks
    • 46231
    Re: Asset Wifi problem
    You have restarted all devices?
    • Taximan
      • Nov 2020
      • 8
      Yes.
        • 46231
        Your music is held on the mac, or a nas? Asset is running on the mac?
        • Taximan
          • Nov 2020
          • 8
          Yes, music and Asset are on the mac.
            • 46231
            Have a look on the Asset configuration page, how many tracks and albums are listed? have a look at the library path to your music, it is correct?
            • Taximan
              • Nov 2020
              • 8
              Library contents are 6756 cuts, 1010 albums. Configuration looks ok. What exactly do you mean by library path?
              Do I need to delete and reload Asset?
                • 46231
                Try a different UPnP control point application to browse Asset, I am certain that Asset is running and showing the correct data. Try Linn Kazoo from here:
                Download the latest software & apps you need to control and manage your Linn system.
                • Taximan
                  • Nov 2020
                  • 8
                  Can you please explain how Kazoo works between Asset and the Cambridge app?
                  Why was it not necessary before?
                  thanks
                    • 46231
                    It would allow you to browse Asset and see if Asset has your albums and tracks.
                    • Taximan
                      • Nov 2020
                      • 8
                      Kazoo recognizes Asset but it just spins and displays "waiting for room"
                      • Heathwood
                        • Sep 2014
                        • 46
                        If I may join the thread, I can confirm that Kazoo doesn't function with my CA streamer a CXN.
                        Has the OP tried access via the CA Streamagic App?
                        • Taximan
                          • Nov 2020
                          • 8
                          Thanks for that. my iPad is too old to support Streamagic.
                          Asset shows up on CA app, but with no content.
                          This all started when my internet service was upgraded. That must be the source of the problem, but I cannot figure out why.
                            • 46231
                            Try 'Lumin' on the ipad.
                            • Taximan
                              • Nov 2020
                              • 8
                              That did it! Cambridge app is now populated with Asset info.
                              I wish I could use the lumin app to control the Cambridge N30, it looks great.
                              Thanksfor the help.
                              t
